Open IFC file ( made in Allplan ) in Revit
1 REPLY 1
oedsdemeer
4189 Views, 1 Reply
1. Open IFC file ( made in Allplan ) in Revit
When converting an IFC file (which is created in All plan) components disappear from the model and some components ( not all ) get a other category assigned (not all floors together etc.). This is what happens in Revit 2013 but in Revit 2011 we did not have this problem.
Are there already improvements/solutions to work better with IFC files?
This is what we allready tried to do:
The orange colored walls and the transparant floor ( V3 ) are invoked differently than the others.
When I “bind” the IFC file now Revit makes the components disappear.
How can we fix this?
1 REPLY 1
Lance.Coffey
in reply to: oedsdemeer
If you have not already done so, it would be good to ensure that you have Update 2 applied for Revit:
If you are seeing this issue with Update 2 applied, check what options are available when exporting from All Plan (e.g. 2x3, XML 2x3).
It would also be useful if you could attach a small sample IFC that demonstrates the issue you are seeing.
Lance Coffey
Technical Support Specialist
Rail Community
