1. Open IFC file ( made in Allplan ) in Revit
When converting an IFC file (which is created in All plan) components disappear from the model and some components ( not all ) get a other category assigned (not all floors together etc.). This is what happens in Revit 2013 but in Revit 2011 we did not have this problem.
Are there already improvements/solutions to work better with IFC files?
This is what we allready tried to do:
The orange colored walls and the transparant floor ( V3 ) are invoked differently than the others.
When I “bind” the IFC file now Revit makes the components disappear.
How can we fix this?
If you have not already done so, it would be good to ensure that you have Update 2 applied for Revit:
If you are seeing this issue with Update 2 applied, check what options are available when exporting from All Plan (e.g. 2x3, XML 2x3).
It would also be useful if you could attach a small sample IFC that demonstrates the issue you are seeing.
