I'm new to Revit and trying to learn the program, so bear with me. In any event, how do does one use the numerical offset to offset an exterior wall and achieve the new offset wall to be in the correct orientation and location, i.e. exterior brick on the exterior and interior gypsum board on the interior?
Thank you,
AB
Hi. When you offset any wall it is offset with the same directions. However, you can simply click on the wall and use the flip arrows to change the orientation at any time. If this doesn't answer your question, maybe you could provide an image to make your question more clear. Regards.
