I'm not able to modify any wall profile, floor boundery, Revir does not give the option to do it, I try to download the update but it didnt work.
Does anyone knows how to fix this issue?
Thank you
Jose
Make sure Lines are turned on in the View. Sometimes if Lines are turned off, users "think" that Revit won't let them edit in Sketch Mode.
Also sometimes the Finish Sketch dialog box disappears and leaves you unable to finish editing--this is usually due to a graphics card/driver problem,
or you need to install the latest Update Release.
I download the update release 3 for revit architecture,
i got this isntallation error
"the update release could not beinstalled because the expected Autodesk product could not be located on your computer. make sure you are using the correct update release for the product
You do not say what version of Revit you are using, but based on the problem and your mention of Update Release 3, I am assuming that it is 2013. Are you running Revit ("one box", with all disciplines available, as provided in the Autodesk Building Design Suites) or Revit Architecture? These are distinct programs with different Update files:
Revit:
Revit Architecture:
