I have a load-bearing masonry wall in an existing building where I need to remove a portion of it to make two rooms into one. The wall will only be removed so that it is above the new ceiling. How do a create an opening in it that is not room bounding? I have a wall opening family, but you cannot choose whether or not they are room bounding. This only works for walls.
Joe
Joe,
The best method for this is to create a wall opening in the existing phase using the Architecture>>Opening>>Wall Tool. Then, still within the existing phase add another wall that fills in the opening, so both will remain (Opening and Wall).
In the new phase demolish the infill wall. This will ensure that the new phase room will 'flow' into both spaces.
I don't like chopping up the existing models however this is the only way to do this.
Good luck,
K
Kevin,
This solution does work for a simple wall, however, I have found that it won't work with stacked walls. If you have two wall types stacked and you only cut through the bottom one, Revit still sees the top wall as the room boundary. I guess I am going to have to cut that apart also to make this work properly.
Joe
Maybe I am missing something, because I don't see why this is a problem. If two adjacent rooms are to become one, select the wall that divides them, set that wall to be not room bounding, then do the opening or do edit profile.
Joe,
The method will work, however when adding the infill wall for the stacked wall Right Click the wall and select break up. This will allow you to modify the height, and remove sections of the infill stacked wall that are above the ceiling.
Alfredo,
if it was just a model of the new construction then your method would work, however I imagine Joe is also creating an existing plan as well that will require rooms. I appreciate that this can be achieved using room separation lines etc, however I don't think this is best practice as the room areas wouldn't be correct.
It's interesting how different people approach the same issue, there are multiple ways to skin the Revit cat!
K
I see. That's the part that I was missing, then, the phases. I did not take that into account when I read the original question in this thread.
@Kevin wrote:
...There are multiple ways to skin the Revit cat!"
Oh, yes, we even have the Revit cat here. 🙂
It was posted by my friend Jeff Hanson at the end of this other thread.
Ha!!! I had forgotten I posted that. I like it being called "the Revit cat". I might have to start posting it everytime I see more than one solution posted to a problem.
There was me trying to be original and quirky!
Not entirely sure, that ive understood your question correctly, but if i did, you can use the "Split tool" on the part of thee wall were the hole is, and make that specifik part "Non room bounding"
Hope this helped 🙂
Have a great day!
