Revit Architecture
New Member
lockmote
Message 1 of 32 (29,412 Views)
No template on my Revit Architecture
29412 Views, 31 Replies
04-10-2011 09:26 AM
hey guys . I just want to ask you . After I installed my Revit Architecture 2012 and I open it
It always say "Default Template File Invalid"
bla bla bla
like on this pict
Can you guys help me out ?
I'm browsing to my computer and I don't find any file that *.rte anywhere
Active Contributor
edwardnoael
Message 2 of 32 (29,378 Views)
Re: no template on my revit architecture 2012
04-11-2011 01:01 AM in reply to: lockmote
Have the same problem.. what to do?
Valued Contributor
Message 3 of 32 (29,355 Views)
04-11-2011 04:04 AM in reply to: edwardnoael
Same problem here,
Two solutions:
1) use RST 2011 template
2) Open the default project and save as template.
But still the question remains, from where to download the 2012 templates?
Raghavendra Bhat
rnbhat1@gmail.com
New Member
lockmote
Message 4 of 32 (29,342 Views)
04-11-2011 05:49 AM in reply to: lockmote
If I use the Revit Architecture 2011 template, will it work perfectly ? Will the program crash or not ?
and where I can download Revit Architecture 2011's template ? Can you give me the link ?
because I'm confused (-.-)"
yes, why autodesk doesn't give the Revit Architecture 2012's templates. They just make us confused of that template
btw, I've downloaded the Revit Architecture 2011 Imperial Template
can this default.rte be the right one for my template for now ?
http://seek.autodesk.com/product/locale/adsk/revit/families/arch/empty/Revit_ARC1157
Active Member
Message 5 of 32 (29,192 Views)
04-17-2011 01:04 AM in reply to: lockmote
Look for the Templates at the following location: C:/ProgramData/Autodesk/RAC2012/Templates/Canada
There I found four, two of them default.  Hope it helps.
Alex
Member
Message 6 of 32 (26,645 Views)
09-21-2011 01:01 AM in reply to: alex_k07
OK I need links to download metric templates, please.  I'd prefer not to have to download - bandwith issues - so if it is hidden somewhere on the installation disk...
Please also tell me where to place them so they can be picked up as default  - in C:/Program Data or somewhere else?
It's OK for people who had 2011 before, but what about those who don't have 2011 on their computers?
New Member
mindaugas1988
Message 7 of 32 (24,205 Views)
12-08-2011 06:45 AM in reply to: tertiab
the same problem for me, I am not able to start working with revit, I am sure that it will help a lot for my studies, but from where get all the templates, and doors, windows, wall predefined models?
Message 8 of 32 (24,077 Views)
12-11-2011 10:57 PM in reply to: mindaugas1988
You could go through uninstall > add or remove components and adding some other libraries which were missed during installation.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Shiny Stephen
Support Specialist
Product Support
Autodesk, Inc.
New Member
mindaugas1988
Message 9 of 32 (24,065 Views)
12-12-2011 03:29 AM in reply to: lockmote
thanks for the answer. So it means, that normally in the student version of Revit Architecture 2012 libraries and templates should be included? It was my mistake that I install it wrong? :smileyhappy:
l.tucker
Message 10 of 32 (24,041 Views)
12-12-2011 11:33 AM in reply to: mindaugas1988
It usually installs alright, but sometimes the content libraries don't install. For 2011 and years before, you can download the libraries from http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13192741. For 2012, just go to Control Panel -> Add/Remove Programs -> Revit Architecure 2012 -> Change/Remove. Once in there, you should be able to add components to your install, such as the content libraries.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
