Is there anyway no wall gap line between floor when I copy 1st floor walls to 2nd floor. Not to use "Join geometry" & Line work: invisible line" tools? See attached picture. Thank you!
Willie
I am not sure I understand your question. But if you want a continuous exterior wall, make it continuous through the height of the building. In other words start the wall at your ground level and have it go up to the roof level. Do not stack the exterior walls on top of each other by floor.
Thanks for your replay!
I don't want to start the wall at ground level and have it go up to the roof level. Is it possible?
Willie
Just curious, why wouldn't you have the wall go from the ground level to the roof? That it is how it will be constructed.
