New vs: Existing walls
3 REPLIES 3
250 Views, 3 Replies
Hello, I am wondering where Revit aquires its information on what lineweight to use for new and existing walls? The new walls show up in plan view with a decent lineweight but the existing are still alittle light. Would that be considered a "thin" line? Or is there somewhere else you go to set up the lineweight for existing wall types?
John Fleming
3 REPLIES 3
The existing wall display is controled by the phase graphic overides, Under settings>phases> graphic overides, you select the display properties you want.
So, there is no way to independently change the linetypes other than globally? Here is what I am getting at. The walls come out to light with the default setting but when I change it to a thicker pen or change the color to black it changes the floor hatch, doors, windows, fixtures etc that didn't need to change. I
The solution is as simple as making new materials/line-styles that are not
used by anything else and using them for existing conditions.
wrote in message news:4840306@discussion.autodesk.com...
