New views are making problems in old views....
3 REPLIES 3
pratheeshjaison
225 Views, 3 Replies
Hi, I am working in revit mep file which linked with revit structural and revit architectural. As per my project requirement, I need to create 96 layouts of the model. When I am creating a new layout, I need to create some new sections and details also. So that section lines is showing in my other layout views……how can I create new sections without affecting other layout views…??..Or is there any option for freeze views..? I don’t want to show new items in selected views…..please help me……
3 REPLIES 3
LisaDrago
in reply to: pratheeshjaison
You are able to hide indivudal section markers and callouts in each view - or you can hide the category all together in the view you want.
But by the nature of the element - it will show in all views.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
pratheeshjaison
in reply to: LisaDrago
The actual problem is, when i am drawing the 95th layout section, that section line is showing all previous views. it means i need to go back to the all 94 layouts and hide that new section line........it will take more than 2 hour extra for updating other layout. That is making me crazy.....
CoreyDaun
Do you have them divided into "sub-categories" such as Demolition and Ceiling Plans? If so, perhaps you can add a Project Parameter (Text, Instance) named "Sub-Discipline" (if it doesn't already exist) to all of your Views. Then, you can add a View Filter to your View Templates that will show only the Sections from the appropriate Sub-Discipline. When you create a new Section View, assign the appropriate Sub-Discipline to it and it should minimize the cleanup duties.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
