New to Revit-Baluster Question
1 REPLY 1
NJD1995
414 Views, 1 Reply
I am working with point cloud data to model a utility room. I have a railing for a catwalk that has irregular balusters. The first baluster is set at the right location but I cannot figure out how to adjust spacing for the remaining ones. Any help would be great. Thanks.
Tags (1)
1 REPLY 1
cbcarch
in reply to: NJD1995
You might need to create separate railings, and specify where the "break" in the baluster pattern should occur, to get the spacing you need.
I have also seen Curtainwalls (with custom mullion profiles created for the railing components) used for odd conditions such as this--the curtain grid positions can be moved and the "mullions" will fill in over them--
Also take a look here:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-426BE12E-A906-457B-A205-A5DFF08B07D7
Edit: It may also be possible to create a single "custom baluster panel" which contains nested generic model families that represent to unevenly spaced
posts/pipes in the existing railing.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
