New in Revit 2015 Subscription Advantage
3 REPLIES 3
640 Views, 3 Replies
Hello. We have just found this info New in Revit 2015 Subscription Advantage in the Revit 2015 help. Various powerful enhancements are described there and are supposed to be available for Subscription customers. Some of these powerful enhancements are:
  • File upgrades: To help you understand the consequences of file upgrades, new dialogs indicate the release of a file and the release to which it will be upgraded.
  • Search: To quickly find the content you need, use the new search feature in the Type Selector or in drop-down lists.
  • PDF Export enhancements: Generate PDF files with automatically linked views and sheets (each view tag in the PDF is a hyperlink).
  • Schedules: To easily add a data row to a schedule, use the Insert Data Row tool
  • User interface for structural elements: To improve productivity during structural modeling
  • Sequence for power circuits: To specify the sequence in which power circuits are created, use the Electrical Settings dialog.
  • ASHRAE table information: To identify the table that is applicable for the current condition, the ASHRAE Table Settings dialog displays the graphical representations associated with the duct fitting tables.
Our company is under Autodesk Subscription, but the current release our IT group has installed in our stations, which is Revit 2015 Update Release 3 Build: 0140606_1530(x64), does not contain these enhancements.
How can we get these 2015 enhancements up and running in our Revit 2015?
Thanks.
3 REPLIES 3
scott_d_davis
These new tools are not yet available to subscription customers. They will be released at a later date. You can preview these tools now by going to the Revit Sundial page here: http://www.autodesk.com/campaigns/revit-sundial
Scott D Davis
Sr AEC Technical Specialist
DarrenP
in reply to: scott_d_davis
this came out today
check your subscription center under product enhancements
DarrenP
ValdisPriednieks
in reply to: DarrenP
I have Revit LT 2015 with subscription. Today I have installed Autodesk Revit LT 2015 R2. There are additional softs Dynamo 0.7 and IronPython Console. For what purpose are these softs? Can I uninstall these?
