As I start a new family and I select the template Specialty Equipment it opens the 4 windows and gives me 2 reference planes. That is all good but when I try to select either one of the reference planes I can not select it. I can add others and I can dimension to them and use them for mirror I just can't select it to rename it or modify its grips.
Any ideas if it is me or a glitch?
Solved by L.Maas. Go to Solution.
