Just create a brand new deployment. In the section where it covers installing content, choose not to install content. In the following window, it will give you an option to specify a location for all of your existing content. This will path your Revit install to the correct support folders.
Typically when I create a deployment, I will open up the supporting cabinet files in zip and extract them to a target folder. Then I will go ahead and create the deployment using the method I described above.
--Regards
Marcus Kim, AIGA
Message was edited by: dydx
null
