Need to tag elements in linked models, AND show the linked model name...
1 REPLY 1
gsucci
541 Views, 1 Reply
Hi all,
I am tagging doors from a linked model.
I need the tags to also show the name of the linked model.
I created a door schedule and the task there is really simple: I just select the door parameters I want to see, then I switch "Select available Fields From" to "RVT Links" and chose the "Name" parameter. Done.
But how to achieve that for Tags?
Thank you
regards
1 REPLY 1
BIMologist_
in reply to: gsucci
I don't think that this is a possibility without coding. The from: parameters are not exposed to the tags. As mentioned it can ost probably be achieved using scripts. copy the data from the schedule to push to a shared parameter in the door
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
