My column doesn't mirror
6 REPLIES 6
729 Views, 6 Replies
Hello guys. I'm having a litle problem trying to mirror one of the columns of my project. It just dont mirror!
Its the P121, im trying to mirror so i can create P122 but in all my trys the result was like the picture bellow.
Can anyone help me with this??
6 REPLIES 6
gustavomello
Hi Felipe,
just tried here with a similar column and worked as expected. Can you attach a small portion of your project? What version of revit are you using? I'm in 2012.
Gustavo
in reply to: gustavomello
@gustavomello wrote:
Hi Felipe,
Gustavo
Hi Gustavo!
Here goes part of the project. Maybe you can figure out whats going on.
Tags (1)
gustavomello
Felipe, for some reason your columns were created as slanted. I changed it to vertical and the mirror wprked perfectly. In case you don´t know already, select your column (all of them preferably) and in the constraint section of it´s parameters change the "columns style" to vertical.
Are you a brazilian?
Gustavo
gustavomello
Hi Felipe. i did write here last night but, for some reason, the post didn't showed up.
For some reason your columns were created as slanted instead of vertical. I changed this and then the mirror worked well. In case you don't now already: select the columns and in the constraint section of it's properties change column style to vertical.
Are you from Brazil?
Gustavo
Problem Solved!!
Thanks Gustavo.
Yeah, i'm Brazilian. So i guess you are too.
Now i'm having another issue with my quantity takeoff. If you can check my other post and help me (again!) i'd really apreciate.
Anyway, thanks again!
Hi, just one question, so what if I actually want to keep the column slanted?
