Revit Architecture
Member
Message 1 of 5 (613 Views)
Multiple building pads sharing common edges.
613 Views, 4 Replies
08-31-2009 06:16 PM
I am modifying topography to include multiple building pads at varying levels and also including sloped pads. I am having a non-consistent problem at the common boundary of some pads. A small sliver of topography sometimes 'sticks through' the common boundary. The height it sticks through seems arbitary, sometimes to the height of the original topography when cutting and sometimes much higher. I have used the copy/paste aligned commands to ensure the boundaries are exactly common but this does not help.
Any suggestions. I have read that some users cut the topography globally and then build up the various levels and ramps using floors and the variable floor thickness command. This seems a bit cumbersome and I imagine would cause problems when cutting sections etc.
Any help greatly appreciated.
Jason
*Anthony Mason
Message 2 of 5 (613 Views)
Re: Multiple building pads sharing common edges.
09-01-2009 08:14 AM in reply to: JJaffers
Does this help?
http://revitoped.blogspot.com/2009/08/pads-and-slope-arrows.html
JJaffers wrote:
> Hi,
> Jason
Member
Message 3 of 5 (613 Views)
09-01-2009 04:50 PM in reply to: JJaffers
Thanks for the help. My first try on one of the problem areas resolved the problem. Fingers crossed for the rest of them.
Greatly appreciated.
Active Contributor
Message 4 of 5 (411 Views)
09-19-2012 12:47 PM in reply to: JJaffers
I, I have the same problem, but the link with the solution is missing. Can you explain what the problem is?
Thank you,
Silvia
Member
Message 5 of 5 (188 Views)
08-17-2013 05:38 AM in reply to: ssoonets
It is also happening to me.
I can manage to set two different levels from this building pad, what displays the last cellar level buried.
Any help will be greatly appreciated
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
