Multiple Monitor Support Wishlist
1 REPLY 1
tkendrick
278 Views, 1 Reply
Autodesk,
Please fix the issues with using Revit on multiple monitors.It shouldn't matter which display the main Revit window is on. Why does it have to remain on the primary? Make the palettes like AutoCAD, removable, dockable windows that remember their positions. Also make it so that there is a better way to have multiple views open and visible as once. I don't find the TILE windows function does what I want it to. With multiple monitors I want to be able to have several views open and visible across different displays. I've tried the AutoHotKey scripts found in the forums and it's just clunky and doesn't cut it. Again having some way to split the view similar to what AutoCAD does would be great.
Please put this at the top of your to do list.
Also, Please vote up this wish on the AUGI Wishlist:
http://forums.augi.com/showthread.php?144890-Multiple-Monitor-Support&referrerid=257808
Use this link to tell Autodesk about features you need:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
1 REPLY 1
lanl
in reply to: tkendrick
Hi tkendrick,
Thanks for your feedback on our software. I would encourage you that report such wish list here:
You can use the form in the link to tell us what you think about our products, their features, and any improvements you would like to see. Then related people will read all the feedback recieved and take what our customers have to say very seriously.
Thanks.
Lei Lan
