Solved by michael.coviello. Go to Solution.
Copy the keynote multiple times, at the same place. Then just drag the arrows to different places.
See illustration.
This is ridiculous way of doing it.. Blaming Autodesk.. not you. I am amazed they don't an option even in 2013.
@narenvangamudi wrote:This is ridiculous way of doing it.. Blaming Autodesk.. not you. I am amazed they don't an option even in 2013.
I would imagine that the reasoning behind not doing so would be that the "extra" leaders would be pure annotation and could point to objects to which the keynote does not apply. Even if all were done correctly on first placement, the objects to which the "extra" leaders point could be changed, and the keynote would still indicate the original, now incorrect, note.
Yes and no. It depends on what type of keynotes you're using. If you're doing standard or material keynotes, then you're right, it makes no sense. However, if you're using the manual user keynotes, then you could be mistagging items.
If you want a single keynote tag to have multiple leaders, then you'll have to create it as a generic annotation element, and it will be a manual keynote that is not tied back to any kind of smart data. You will, however, be able to add multiple leaders to it (same way as adding multiple leaders to a text object).
So, since there are several different ways of doing keynotes in Revit, having multiple leaders as an option with all types isn't possible.
Hello @Mikeb
I came across this post today and wanted to share this information. I understand the thread is quite and you may already know about this but wanted to share.
Multi-Leader Tag Leader Enhancements (What's New in 2023) | Revit 2023 | Autodesk Knowledge Network
