It is a challenge to search for answers to questions because people use different jargon to represent the same thing. Additionally, the jargon for AutoCAD is not necessarily the same as for Revit. I have been trying to find how to control the width of a column of multiline text. At the most primitive level, there does not seem to be a place where you can type in the desired width of the text column. In looking for workarounds, I can draw two parallel detail lines to represent the desired column width, but the text box does not snap to anything. Changing the text column by pulling one of its handles in a hit and miss thing. This might be ok for one text column, but if I have multiple text columns that I want to layout withing a legend or on a sheet, there seems to be no exact control.
Thanks for the suggestion but I am unable to figure out how it works. Do you have a generic annotation family you could share so I can examine its paramaters more closely and insert into project to see how it works?
