Revit Architecture
Distinguished Contributor
kate_vanhout
Message 1 of 7 (1,576 Views)
Moving Objects Between Design Options
1576 Views, 6 Replies
08-10-2012 08:34 AM
I am using Revit Architecture 2013 and I have a few different design options for the mian level of a house I am working on.  I have the North wall of the house in a design option for the living room at the moment.  But I have decided I no longer want that wall in the my living room option, I would like to move it to my kitchen design option so I am able to move a window that is located on that wall.  I cannot seem to find a way to move a wall from one design option to another or have it in both if it is already part of a design option.  Does anyone have any suggestions on how I can get this wall and the windows located on it into my kitchen design layout without having things being double counted in the schedules?
Employee
davissc
Message 2 of 7 (1,570 Views)
Re: Moving Objects Between Design Options
08-10-2012 09:40 AM in reply to: kate_vanhout
use Cut and Paste.  Select the objects you want to move, and Cut them using Crtl-X or the Cut toolbar button in the ribbon.  Make the option active you want them in, and then use "Paste same place" from the ribbon.
Scott D Davis
AEC Technical Specialist
North American Sales
Want Revit Content? Go to http://seek.autodesk.com !
kate_vanhout
Message 3 of 7 (1,558 Views)
08-10-2012 10:58 AM in reply to: kate_vanhout
Thanks so much this worked!!
Active Member
sheenasharp
Message 4 of 7 (1,028 Views)
10-06-2013 09:02 AM in reply to: davissc
The solution did not work for me.  the wall shoudl remain in the main model, and be added to the other option.
this solution removres the wall from the optionA and would not paste into Option D.
Alfredo_Medina
Message 5 of 7 (1,019 Views)
10-06-2013 09:42 AM in reply to: kate_vanhout
The original question refers to "moving" an element from one option into another one, and the solution of the copy-paste and changing the current option works for this question. Perhaps your case is different.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Active Member
sheenasharp
Message 6 of 7 (1,012 Views)
10-06-2013 09:59 AM in reply to: Alfredo_Medina
I think you are correct.
My problem is that all the elements seem "locked" in the main model view,
so I cannot add them to the new design option.
I have been struggling to find the problem, to no avail so far.
Sheena.
Sheena Sharp
Principal
Coolearth Architecture inc.
386 Pacific Avenue
Toronto, ON M6P 2R1
p 416-868-9774
c 416-575-5928
Alfredo_Medina
Message 7 of 7 (1,000 Views)
10-06-2013 11:00 AM in reply to: sheenasharp
Maybe there is a confusion about the usage of design options? Main model is the set of the elements that are common to all the design options. In what case do you need to move objects from the main model to an option set?
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
