221 Views, 3 Replies
Move
Is there a way to move a group of objects a specified distance, without
editing the ghost dims that pop up? maybe I don't understand how thy work.
?? if I had a line out of whack in the middle of a bunch of lines how could
I move several of them say 3/32"? I'm trying to make a title block, if that
makes any difference. is there a way to get a bunch of the ghost dims to
show up to edit? how would I edit a annotation dimension, to update it's
distance similar to the ghost dimensions?
Any help is greatly appreciated.
Matthew
3 REPLIES 3
You've asked at least three different questions here. I'll answer only the first or main one. Select the several objects, then pick a point, drag the cursor in a given direction, then type in the distance.
Maybe either training or another pass at the tutorials might be in order.
That is not working. Whenever I try to type something I get a beep for
every keystroke.
is there a setting to turn that on.
wrote in message news:6238717@discussion.autodesk.com...
LisaDrago
do any of the dimensions turn blue when you select something to move?
if it does click on it and try typing in a distance there.
Can you post an image of what you want to acomplish?
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
