Revit Architecture
Active Member
dupuisj
Message 1 of 1 (262 Views)
Move project to the 0,0,0 of the intern coordinate?
262 Views, 0 Replies
09-05-2012 02:26 PM
Is there a way to move a project to the 0,0,0 internal coordinate of Revit? I often have to insert different Revit link in a project so I’m trying to make easier the insertion of a revit link (for example a structure Revit link into architecture Revit file. If all the Revit file use the point (0,0,0) of the Revit project internal coordinate, I could use origin to origin to place the link without having to move the link. I know that I can use the shared parameters but I have to place manually the link at the right place the first time. Is there another way to do this? I tried to use the API to move the project, but I have got problems to move elements that are associated with a Work Plan and to move on the Z axis.
Thanks.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
