Good morning folks,
I wonder if you could give me some guidance please on moving project files from Revit Server back to windows explorer environment without having to open each individually via Revit itself.
I am an administrator and have access via the web admin interface to view the files, however it doesnt seem to allow files to be downloaded or copy and pasted from there to WE.
The reason I ask for assistance is that there a lot of files to be moved (circa 60) and this can be a teadious and time consuming process. I'm sure it took me the best part of a day to load them all up there in the first place.
Many thanks for your help in advance.
Jon Arnott
BIM Co-ordinator
Scott Brownrigg
Solved by lanl. Go to Solution.
