Revit Architecture
New Member
Message 1 of 4 (359 Views)
Monolithic stair u-shaped
359 Views, 3 Replies
07-10-2013 03:40 AM
I have made a stair by sketch, an u-shaped one. I do have som problems with the 3d modell. it will not show up correctly. I add som printscreens and you can see. You know what i have to do to fix this?
*Expert Elite*
doni49
Message 2 of 4 (301 Views)
Re: Monolithic stair u-shaped
07-12-2013 11:38 AM in reply to: glenn.roar.hoye
The first thing that comes to mind is that the view is cropped.
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Valued Mentor
gh_ar
Message 3 of 4 (290 Views)
07-12-2013 01:16 PM in reply to: glenn.roar.hoye
Hi
Use one of the following methods may be your problem.:
1 - Reduce the thickness of the stairs.
2 - in the landing areas, with separate Split.
3 - In the Type Properties and Type Properties dialog box, click Run type in new window Stepped put option on the Underside Surface.
4-Monolithic type steps of change.
New Member
Message 4 of 4 (118 Views)
01-08-2014 08:11 AM in reply to: gh_ar
Everyone should thank you so much!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
