Revit Architecture
Valued Contributor
roothcad
Message 1 of 4 (509 Views)
Monolithic Stair with missing tread
509 Views, 3 Replies
01-31-2012 07:03 AM
Is anyone else experiencing monolithic stair with top tread missing - see attached image. The plan has irregular treads and I did pull the top riser line away from the boundary intersection but it had not affect.
Any sugestions for a workaround?
Or is this just a "feature"
Product Support
fernanda.firman
Message 2 of 4 (447 Views)
Re: Monolithic Stair with missing tread
02-15-2012 12:56 PM in reply to: roothcad
Have you checked the "begin with a riser" option?
1.Select the stairs
2. Edit Type
3. Under Riser > check: begin with a riser
Hope that helps.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
Valued Contributor
roothcad
Message 3 of 4 (425 Views)
02-17-2012 01:20 PM in reply to: fernanda.firman
The stair is set to "begin with riser" and it drew that riser along with all the others - it's the tread that missing.
Distinguished Contributor
shawn
Message 4 of 4 (404 Views)
02-18-2012 12:54 PM in reply to: roothcad
In my experience, which is probably similar to yours, meaning not an expert, I have found that with stair problems, the only solution sometimes is just to play with every conceivable combination of settings and adjustments until something goes wright.
Typically it's some small thing that just needs tweeking or some option or variable, such as max. tread depth, etc. that needs to be changed. Revit is extremely fussy if you don't do things exactly the way it wants Have fun.
S.G.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
