I have a finished revit model and i am trying to use it to help the construction process. All the floors in the museum are concrete floors, and because of the large spans that they have to cover, the concrete has to be poured as a dome shape (please see picture), so when the formwork supports are removed, the concrete slab will deflect under it's own weight and level out. so here is my question: can you modify the floors using pick points to represent this dome shape? when i modify the floors in revit, i add pick points and then pull them up, and revit modifies the floor using straight lines, where as i need curved lines. i have attached a picture of what i want the floor to look like when i pull the pick points up. is this possible without having to re-draw all the floors?
thanks,
Matt
