Modifying View Titles
2 REPLIES 2
gmak
160 Views, 2 Replies
I'm still coming to terms with Revit (after switching from ADT), and generally I love it. It's so much more intuitive and closer to the way you 'want' to work rather than how it will 'let' you work.
A few things are give me some headaches at present...
The attached image illustrates:
the section on the right - how can I get the text to appear on a single line? I don't seem to have any control over this, and it would be nice to be able to change view titles after they are assigned.
2 REPLIES 2
in reply to: gmak
Open the viewtitle family and make the label for view name longer. The text wraps based on the size of the text boundary in the family. "gmak" wrote in message news:23929069.1084895210974.JavaMail.jive@jiveforum1.autodesk.com... > Hi, > I'm still coming to terms with Revit (after switching from ADT), and generally I love it. It's so much more intuitive and closer to the way you 'want' to work rather than how it will 'let' you work. > > A few things are give me some headaches at present... > > The attached image illustrates: > > the section on the right - how can I get the text to appear on a single line? I don't seem to have any control over this, and it would be nice to be able to change view titles after they are assigned. > > Thanks
in reply to: gmak
Once done adjusting viewtitle family do not forget to load it into project so your changes propagate there. "Frame" wrote in message news:40aa33a8$1_3@newsprd01... > Open the viewtitle family and make the label for view name longer. The text > wraps based on the size of the text boundary in the family. > > "gmak" wrote in message > news:23929069.1084895210974.JavaMail.jive@jiveforum1.autodesk.com... > > Hi, > > I'm still coming to terms with Revit (after switching from ADT), and > generally I love it. It's so much more intuitive and closer to the way you > 'want' to work rather than how it will 'let' you work. > > > > A few things are give me some headaches at present... > > > > The attached image illustrates: > > > > the section on the right - how can I get the text to appear on a single > line? I don't seem to have any control over this, and it would be nice to be > able to change view titles after they are assigned. > > > > Thanks > >
