Modify text size for project browser and properties boxes
3 REPLIES 3
3254 Views, 3 Replies
I have purchased a large monitor and would like to reduce the size of the text in the dialogue boxes, i.e. Project Browser, etc. Can this be done?, and if so how. The same goes for the Panel button.
3 REPLIES 3
kathryn.langan
Hi Steve,
The text size in the UI is controlled by your resolution in Windows. If you go into Control Panel > Display you can adjust the size of the text, which will adjust it in Revit.
I hope this helps!
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
in reply to: kathryn.langan
Hello Kathryn,
i have a middle monitor and I'd like to amend th e size text in project browser in Revit. Is there any solution to change in Revit? To write an value to another?
Normally really to large the project browser test size, and when you have more then 100 views it is very hard to navigate!!!!
thanks Tom
bdekk1
It's already at 100%....this does not help the issue.
