If I want various brick patterns on the exterior walls and i want to study it in 3D views, I have to create a wall for each different brick pattern, correct? Or, is there an easier way?
@david.rosen wrote:"create a wall for each different brick pattern, correct? Or, is there an easier way?"
You can assign a different brick pattern to different instances of
the same wall.
Or you can render the one instance of that wall more than one
time, each with a different brick pattern.
So, do I need to duplicate the wall before assigning a different brick pattern. Is that what you mean by an instance of the wall, because to me that is a new wall. Thats ok, its how i would have done it unless there is a quicker way.
What I mean by instance is just drawing the same wall
type in a different location. (An "instance" of that wall).
I'm not sure if you want to see the exact same wall rendered
with different bricks, or different pieces of the same wall
rendered with different bricks.
In any case, you can use the "paint" tool to paint any wall
finish to any piece of wall, wall type or any part of any wall.
When you click on the paint tool you get a list of all the
material finishes available to use on whatever surface
you paint it on, instead of going into the wall properties
and assigning a new material finish.
Edit: You can also divide the surface area of a wall face, called
"split face", and have more than one kind of bricks stacked
on top of each other on the face of one wall.
You can also stack smaller bricks on top of larger bricks
where the large bricks would be set out from the smaller
ones on top. That's called "stacked wall".
I didnt realize paint would work on 3D models as well. that is definitely the quickest way to study masonry patterns as opposed to creating different walls to acheive that. perhaps I would do that for the final modal in order to cut accurate wall sections. maybe not. thankis!
This is really exciting. All I have to do is define a bunch of materials with the patterns and colors I want to explore. Then I can create the model with generic walls because all I care about is the patterns on the outside walls. This makes the modeling process much more quicker.
@david.rosen wrote:I didnt realize paint would work on 3D models as well. that is definitely the quickest way to study masonry patterns as opposed to creating different walls to acheive that. perhaps I would do that for the final modal in order to cut accurate wall sections. maybe not. thankis!
How do you plan to "cut accurate wall sections" if you are applying materials as paint?
Sections will come later.
As of now question is 'I want various brick patterns on the exterior walls and i want to study it in 3D views'.
For study purpose 'split and paint' is the first solution came to my mind.
One can apply different brick pattern on same wall in different parts and can easily do the comparision.
Once finalize on one, he can remove all others and proceed wth the next level (detailing where section comes in picture).
