Hi every one, I am doing the structural frame of a house with curved walls and I needed to use the Model in Place command to create a curve shaped column. I defined it's category as Structural Column, but it takes the fill pattern of the wall. When I isolate the column, it has the same fill pattern as the column from the library. I need that the column will be displayed as the other structural column. Please see the attached image.
Any help will be helpfull.
Thanks in advance, Alex
Maybe create a material parameter for that in-place column
and set its graphics properties in the material editor to the
pattern you want.
