I´ve created a component (furniture) with some extrusion solids and some voids.
It shows fine in the 3d view, but in plan view (hidden lines) the void doesn´t cut the solid extrusion. See the image attached.
Can anybory help me? Thx
PS.: I´m using Revit 2014 with the Update 2. And I've checked the cut plane offset too.
Solved by AJA14. Go to Solution.
Can you send me your Revit file?
Thanks & regards,
Subhradeep Sen
Kolkata
India
