How do you change the direction of a model hatch that is seen in 3D view?
I want to change the pattern of wood planking that goes horizontally to go vertically (in plan view).
Thanks you!
Solved by ccollins. Go to Solution.
Use the Tab key to select a line in the pattern, the use Rotate.
cheers
You can modify the surface pattern of model componets in a number of ways. Here is a link to the section of the wikihelp on controling the surface pattern of mopdel elements.
