Model hatch direction
2 REPLIES 2
3435 Views, 2 Replies
How do you change the direction of a model hatch that is seen in 3D view?
I want to change the pattern of wood planking that goes horizontally to go vertically (in plan view).
Thanks you!
Tags (2)
2 REPLIES 2
Use the Tab key to select a line in the pattern, the use Rotate.
cheers
loboarch
You can modify the surface pattern of model componets in a number of ways.  Here is a link to the section of the wikihelp on controling the surface pattern of mopdel elements.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
