The best practice is to have each discipline (arch, struct, MEP) have
separate models. Link them into each other or into a master master. This
will allow you to do interference checks. Revit 9 has improved the linking
capabilities of Revit models to help accomplish this.
Linking is the key here.
Hope this helps.
David Haynes, AIA
Ideate, Inc.
www.ideateinc.com
wrote in message news:5150513@discussion.autodesk.com...
We are about to give revit building and structure, and systems a test run.
We have both Architects and Engineers in the same office. What's the proper
way to mix Revit Building and Structure? Do the structural guys link to the
Building model and build their components independently of Building, or can
worksharing accomodate the two different softwares.
Does worksharing have any affect on the Analytic modelling that structure
does, or is it best to only link?
I would hate to go down the wrong path, so any advice is appreciated.
