Every so often while i'm working in Revit the Ribbon/panel bottoms disapear. Even when toggling threw the options i can only get some of it to reappear. I attched what it looks like and when i toggle through the options. Does anyone know what is causing this issue?
Hi Benway,
What happen if you minimize the panel? Click several times until it's maximized again.
Do you see your panels reappear?
What is your graphic card? I see this several times, and in my case it's the graphic card.
This did not work for me.
After restarting Revit the ribbon was complete again, but that's a cruel way to make it wright again.
Grts, Erick
Do you have extended monitor?
Sometimes two monitors one of which can take high resolution forces other
screens resolution higher as well creating inconsistency..
it is little annoying how revit behaves on laptop screens.. even on higher resolution..
Known issue 😞
How to solve: just click on expand/reduce (the button on the extreme right-up of the window, just next to the "X" button ..^_^..)
