Revit Architecture
*Doug
Message 1 of 8 (93 Views)
Mirroring
93 Views, 7 Replies
03-19-2004 04:53 AM
I am having a problem with mirroring. When I mirror a stair the hand rails detach from the staim and mirror 90 degrees from the stir horizontally but the same stair will mirror properly if I mirror vertically. Anyone else having this problem? Revit 6.1 Thanks Doug
*Aaron Rumple
Message 2 of 8 (93 Views)
Re: Mirroring
03-19-2004 06:20 AM in reply to: *Doug
Try grouping the stair and rail first? I'm flipping stairs with no problem here, but I have them grouped with some associated details. "Doug" wrote in message news:405aed57_1@newsprd01... > I am having a problem with mirroring. When I mirror a stair the hand rails > detach from the staim and mirror 90 degrees from the stir horizontally but > the same stair will mirror properly if I mirror vertically. > > Anyone else having this problem? > > Revit 6.1 > > Thanks > > Doug > >
New Member
placeswb
Message 3 of 8 (93 Views)
Re: Mirroring
06-09-2004 01:07 PM in reply to: *Doug
Grouping worked to keep the railing with the stair when mirrored, but I still got a duplicate set of straight horizontal rails at 90 degrees to the stair I mirrored. The good news is that deleting this bonus set of railings doesn't seem to affect either the mirrored or original stair.
*Jeffrey McGrew
Message 4 of 8 (93 Views)
Re: Mirroring
06-09-2004 01:33 PM in reply to: *Doug
Doug wrote: > I am having a problem with mirroring. When I mirror a stair the hand rails > detach from the staim and mirror 90 degrees from the stir horizontally but > the same stair will mirror properly if I mirror vertically. > > Anyone else having this problem? I've run into this too. Seems a bug. Grouping them helps, but you still get an 'extra' railing to delete. -- Jeffrey McGrew Application Specialist BSD AEC Technologies, a division of ID8 Media Inc. (415) 593-6000 x 129 (415) 593-3333 Fax (415) 505-4689 Cell www.aectech.com www.id8media.com
Active Member
Bud Hester
Message 5 of 8 (93 Views)
Re: Mirroring
06-11-2004 12:50 PM in reply to: *Doug
I'm having the same problem. New to Revit. Thought I was doing something wrong. Sounds like something we will just have to work around, huh?
*Arfath
Message 6 of 8 (93 Views)
Re: Mirroring
06-13-2004 07:14 AM in reply to: *Doug
hi, I faced the same issue, but it seems grouping them solves the issue. After grouping i did't had to delete any extra railing. FYI... Hope in future releases we dont need to trick the revit this way... Eat Revit, Drink Revit, Sleep Revit.... "Doug" wrote in message news:405aed57_1@newsprd01... > I am having a problem with mirroring. When I mirror a stair the hand rails > detach from the staim and mirror 90 degrees from the stir horizontally but > the same stair will mirror properly if I mirror vertically. > > Anyone else having this problem? > > Revit 6.1 > > Thanks > > Doug > >
New Member
shane.trammell
Message 7 of 8 (93 Views)
Re: Mirroring
09-13-2004 11:35 AM in reply to: *Doug
i am having this same problem. i am new to revit and cad stuff so how do i go about grouping the railing and the stairs?
New Member
shane.trammell
Message 8 of 8 (93 Views)
Re: Mirroring
09-14-2004 12:26 PM in reply to: *Doug
nevermind, i got it.
