Thank you,
I'll make a copy of the file and give it a try.
After reading do I keep both copys the mirror and non mirror copy in the
same file?
I was thinking I could call the room names like : living rom and R living
room and filer out the names in the finish schedule, if possible?
Is it possible to group one so the other reverse floor plan would up date???
I'm only have 3-4 months into revit, w/ 7 projects completed revit.
thanks for your help.
Don Sutherland, Architect, AIA
Email: don@dwsarchitects.com
wrote in message news:4921812@discussion.autodesk.com...
There is a thread at the AUGI Revit forums that outlines how to tackle this
if you are interested in going there, you have to join, it is free.
http://forums.augi.com/showthread.php?t=7259
(look for the post by Jim Balding)
While many users think that it is or should be a simple task to mirror an
entire building model and all documentation related to it, it is not. The
Revit developers understand the wish and I'm confident they'll figure it
out. For now however, it remains just as difficult a task as it would be to
do the same task in regular cadd, when you factor in the mirroring effect on
every plan, elevation, section and detail in a set of documents.
