Revit Architecture
Active Contributor
Message 1 of 5 (2,690 Views)
Materials don't export with FBX
2690 Views, 4 Replies
02-23-2011 12:28 PM
When exporting to FBX, the materials don't work anymore. What happens now is that everything exports as one generic material. This worked fine in 2010, but doesn't work in 2011.
PLEASE FIX THIS ASAP ! ! ! !
It is hugely inconvenient and time-consuming to have to export a model material by material. It's playing havoc with my deadlines. Please respond and let us know when we can expect Autodesk to correct this problem.
Message 2 of 5 (2,673 Views)
Re: Materials don't export with FBX
02-23-2011 07:00 PM in reply to: jnegri
You may be having problems with different versions of software. the materials being transfered in revit 2011 to Max 2011 are new material types, that  might be causing you these problems.
If you create a new model in revit 2011, export to max2011 the materials will come across.
cheers
rec
Active Contributor
ariyani
Message 3 of 5 (2,665 Views)
02-24-2011 12:32 AM in reply to: jnegri
only export to max design
Employee
ryan.duell
Message 4 of 5 (2,656 Views)
02-24-2011 05:06 AM in reply to: jnegri
Additionally I would reference the following post as there were numerous updates for 3DS Max which addressed some FBX material issues:
http://revitclinic.typepad.com/my_weblog/2011/02/revit-2011-fbx-to-3ds-max-2011-tips.html
Thank you,
Ryan Duell
Revit Clinic
@revitclinic
Member
hagoyo
Message 5 of 5 (2,492 Views)
04-04-2011 02:55 PM in reply to: ryan.duell
i'm having the same issue - did you find a fix?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
