In the Materials dialog box, when you click on your material, there are 2
options. One is Shading and there's a dialog box labeled Color, this is for
when you click on Shading in a View window. Change the color to something
more suitable. The other opion in the Materials dialog box is Accurender,
there's a dialog box labeled Texture, this is for when you Render a scene.
If this doesn't solve your problem, then it might be b/c the object hasn't
been assigned the material yet. Couple of things to try is to click on the
object and go to properties, check and see if there's a parameter set up
yet, if not assign it a Material parameter and then set it in the Family
Types dialog box. Or you can check on the Subcategory layer, if it's a dwg
imported object, in the Object Styles dialog box. There's an option for the
Material next to the layer. Just depends on how the family was setup.
wrote in message news:5370940@discussion.autodesk.com...
I was trying to change the materials of several components I loaded from the
web library. First I set up a new material parameter and put in all the
specs I wanted but now it wil not "stick" to the component; they stay white
even though the properties box says the right thing.
What am I doing wrong?
