Material width/material length VS type width/type length,
I’m not sure why the Revit doesn’t have fields that represent the “material width” and “material length” but has only the “type width” and “type length”!
For example, in the attached screenshot the Revit shows the width of the type but fails to provide “material width” nor the “material length”!
Also, even the Revit fails to show the accumulative “type length”! what if I wanted to know the total length of the two walls indicated in the screenshot?
Thank you
Best
Jamal
Solved by constantin.stroescu. Go to Solution.
Hi Jamal,
I don't know about material width or length but you can create some parameters with formulas to make that work.
When something is not displayed in a schedule, it means there is a difference between the elements. It says count = 2. If these 2 don't have the same length revit won't know what to display.
Dunno if that's the problem but just an idea.
for material width it can be done as follows:
in Material Takeoff Properties >Fields>Calculated Value ..make a new field ..call it mat width ,common, type>length,
Formula: Material:Volume / Material :Area
It seems it is indeed a problem with Length Material ..it is shown as equal with the Wall Length calculated on wall center line...
I saw you have activated in your schedule in Sorting/Group > Sort by :Material Name if you Itemize every instance the length value will be shown...but not the length sum
Activating Parts and making a Part schedule the Length, Height ,Thicknes,Area,Volume....looks surprisingly accurate...it makes also length sum.......but I still asking myself if this can be used for the whole project...to make parts from every wall and floor...seems to be madness..
Constantin Stroescu
Perfect. This is great Constantin! It works fine and solved my issue
As for the length, there should be a way (as genius as the one you have provided for the material width) to sum up the lengths! For example, one can know the total length of the “Block” or “concrete” walls in the project without the need to itemize them.
All the best
Jamal
