Material on Stacked Wall doesn't change when I change the Basic Wall
1 REPLY 1
Stephm419
1274 Views, 1 Reply
I have a stacked wall. When I change the brick color on the basic wall in shading with edges, it doesn't update the stacked wall? I am using RA 2010.
Any suggestions
1 REPLY 1
ryan.duell
in reply to: Stephm419
The stacked wall face appears to have been painted with another material.  If you add a new instance of the same stacked wall or set the paint material to <by category> it appears correct, and immediately changes to represent a new material change:
Video example: http://screencast.com/t/QcqPQSd2I8
Thank you,
Ryan Duell
