Revit Architecture
andrea.pontiggia
Message 1 of 3 (165 Views)
Material for rendering
165 Views, 2 Replies
12-14-2012 10:05 AM
Duplicating and renaming a material, if I try to change the characteristics Revit also modifies the original material.
What is the problem?
thanks
Andrea
Distinguished Contributor
alex60
Message 2 of 3 (158 Views)
Re: Material for rendering
12-14-2012 10:58 AM in reply to: andrea.pontiggia
It is the most common issue in the new material editor, after duplicating the material you also have to duplicate the appearance assest, then go to the information box and rename the assest. If you don't make this, Revit will modify the original assest.
I hope this will help you, Alex
Valued Mentor
gh_ar
Message 3 of 3 (136 Views)
12-15-2012 02:20 AM in reply to: andrea.pontiggia
hi
The following methods can be used to create personalized materials.
1-The window material and the material below the window and click on New icon to create a new article.
2-Now open the list of descriptions and details and enter a name for the type of material it can also specify
3-You can also click on the button Open / closes asset browser with default material instead
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
