hello
i'm quite new to revit and am having issues with renderings in cloud, my computer is too slow to do this directly in revit. the colours and materials that i have assigned to cladding panels just comes out as grey. i have been thorugh suggestions on some of the other posts, unistalling, reinstalling materials library....changin the settings in 'material editor'....anyone else come accross this and knows a workaround!?
incidentally when i do a draft render on my computer to 'screen' or 'printer' it shows the correct colours.
thanks
Hi. I am guessing that you changed the properties in the appearance assets but the names are still the same, so these assets in the cloud override your material. If this is not the case then your best option would be technical support.
Regards.
