Revit Architecture
Valued Contributor
EnlInt
Message 1 of 3 (365 Views)
Material Take Off - Weight Visible Parts
365 Views, 2 Replies
10-07-2013 02:07 AM
Community,
I was hoping to do a material takeoff for weight calculations. I use families where some parts are hidden depending on use. As an example I have frames were if two of those frames are next to eachother the left or right part of one of those frames will not be used. I use a visible parameter to hide that part. I use Material: Volume and Material: Density to calculate the weight of the frames.
Unfortunately the material take off seems to use the hidden parts for calculations So if I hide part of the family the weight in the material take off does not change.
Am I missing something? Or is there an easy workaround?
I have done weight calculations inside the family, however it requires many parameters and many formulas to get proper resuts.
Thanks in advance for your input.
LM
Valued Contributor
EnlInt
Message 2 of 3 (346 Views)
Re: Material Take Off - Weight Visible Parts
10-07-2013 03:52 AM in reply to: EnlInt
After further reviewing I found the problem/solution.
In the families I use other nested families. In the parent familiy I switch of the visibility setting of the nested (child) family. However this means that the objects/material inside the nested family itself is not hidden. The solution therefore is to use the visbility setting of all the objects insde the nested family and use parameters to control the visibility of all the objects inside the nested family.
Hope this will save other people some time.
LM
constantin.stroescu
Message 3 of 3 (344 Views)
10-07-2013 03:54 AM in reply to: EnlInt
hidding acts only in specific views ...
If you want that some of the objects not to appear in Schedule and in Material Takeof , then apply Filter (can be Comments, Mark , Description)  - in my example a Filter by Comments....
Constantin Stroescu
BIM Manager AGD
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
