Masses vs. Walls
1 REPLY 1
263 Views, 1 Reply
Masses vs. Walls
I'm trying to build a wall that has the concrete block pattern that's offset by 1/2.  If I build a wall using mass then I can make it into a pattern that I want but then I can't paint it so that's it's clear or see through.  On the other hand if I build a wall just using the walls then I can't find an option for the block pattern.
Thots?
Maybe I'm just secretly blonde.... LOL
1 REPLY 1
LisaDrago
Okay - what do you mean by offset by 1/2?
and attached is an image on where to place the surface pattern. in the materials you can specify the surface pattern.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
