Hello, asking here because I am stumped.
I want to manage the pinned recent files for my team. While education on how to use these pins is great for the team. I want to set the top 5 to be certain files.
I do not know how to control the pin setting. I would assume it was in the USER Revit.INI file, but it is not. It must be an application setting somewhere and I have combed through the registry settings as well with no luck.
Has anyone came across these settings before? Where does revit remember that these items are pinned?
Thank-you,
Hi Phaex,
that's stored in the UIstate.dat
%appdata%\Autodesk\Revit\Autodesk Revit 2014
(or 2015 of course)
Cheers!
Thanks for the help. Is there a way to edit this file? At least see what it contains to decided if I want to set mine, then overwrite my user's files.
