Revit Architecture
Valued Contributor
Message 1 of 2 (65 Views)
Making windows
65 Views, 1 Replies
05-11-2005 07:40 AM
I am trying to make a window type. In doing so I have come up with a problem that I cant seem to fix. The window I created looks great when I am editing it....all the mulls line up with the outter frame and the glass is set in the middle. When I load it into my project....which is a cavity wall. the frame sets to the face of the brick and the mulls and glass remain centered on the wall. WHY??? what is needed to keep the window together and set a certain distance from the face of the wall? Also, I am trying to create a soldier course Head and rowlock sill. I cant seem to locate the hatch patterns on the materials for it to look like it should in elevation...any hints on where and what to do for that? Thanks to all for helping
Distinguished Contributor
Message 2 of 2 (65 Views)
Re: Making windows
05-11-2005 09:32 AM in reply to: wubbena
In plan I typicaly set up ref. planes parallel to the wall, then dimension from the exterior face of wall to the first ref plane and call this Inset. Then dim from that plane to the next and call it frame width. this lets me build my window with the ability to control where it sits in the opening. I then create a third ref. plan inbetween those two called glass CL I put a dim that is EQ/EQ on it Now I can create all the geometry I want from that ref plane and it will move with the frame. See attached example.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
