I'm illustrating a second level floor plan and lower level roof in the same view. I set the underlay to Floor 1 so the walls below the roof would show.
I then created a floor substrate above my floor joist with a 3/4" thickness in order to block out the first floor walls below the 2nd floor. I want the substrate to be opaque but I can't get it set that way. I select it, override graphics in view, and set the transparency to 0 but this doesn't work. How can I accomplish this? See attachment. The shaded area is the second floor substrate.
Thank You
Solved by vanderloo5. Go to Solution.
As I understood you want to show only the lines from the first level that are outside the highlighted surface (floor).
I use the following method.
Select an entity from Underlay Level > View >Linework > Line Style > select a wanted line type and click an all entities I want to be seen.
After completing the operation, I turn Underlay from Properties to None.
Now only changed lines will appear.
The lines are annotation lines , visible only on this View, but they are conected to the underlayed level. Changes in the bottom level will show in the made linework ( don"t erase the lines..this will affect the underlined level)
Constantin Stroescu
Thank You Constantin.
But I ended up doing this and it all worked fine-
I took out the underlay and changed the view depth to Floor 1. That made the walls under the floor not show.
Then I selected the roof and changed the transparency to 30 which half toned the walls below so you could distinguish between the upper and lower walls.
you are welcome....Your method seems to suit better in this case.
But,thinking at the printed sheet, why not :
Constantin
Constantin Stroescu
