Louvre family not showing up in elevation
4 REPLIES 4
2476 Views, 4 Replies
Hi. My concern is regarding a louvre family i am placing on walls in a multi-storey commercial project. They are viewable in 3d mode and Floor plan view but when i switch to elevation, all i get are holes in the walls where the louvre should be sitting. Any help would be an appreciated. This louvre family is from Breezway and i am getting the same result with all Breezway family members i have downloaded.
Shandor Fahrenfort
sfahrenfort@hotmail.com
4 REPLIES 4
loboarch
in reply to: 1057583
Looks like there is a bad visibility setting in the family.  Post the RFA file so someone can take a closer look.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
in reply to: loboarch
These are the louver family files I am using with Revit 2012. If there is a fix please let me know it in case I come across the problem again. Thanks.
loboarch
The family has the louvers set to not display at course level of detail.  if you change the detail level of the view the louvers will show up.
Jeff Hanson
Revit Help |
Thanks alot. That fixed it 🙂
