Lost my sheet! What happened
1 REPLY 1
Michelle Gibson
962 Views, 1 Reply
There must be a simple explanation?
Created new sheets for the first time today, then created 3 interior elevation sheets based on room views. Worked great, done in a few hours!
Went back to first elevation sheet and moved a few views around, then when I zoomed out again, the sheet and border etc... is no longer there.
I would've thought that if I deleted the sheet by accident, then I would've lost all the views that I put on the sheet, but they are still there, floating in space!
How do I get the sheet back, or do I simply make a new sheet, move all my views onto that sheet, then delete the sheet that is missing the border?
HELP!
1 REPLY 1
in reply to: Michelle Gibson
If your sheet is still listed in project browser then you probably deleted the titleblock but sheet itself is still there. Attempt to do a zoom extents just in case you actually moved titleblock far away from your views. If you still don't see your title block then add a titleblock by dragging it from project browser (under Families | Annotation Symbols) and dropping it in a window that shows views. "Michelle Gibson" wrote in message news:10371489.1112050334416.JavaMail.jive@jiveforum1.autodesk.com... > There must be a simple explanation? > > Created new sheets for the first time today, then created 3 interior > elevation sheets based on room views. Worked great, done in a few hours! > > Went back to first elevation sheet and moved a few views around, then when > I zoomed out again, the sheet and border etc... is no longer there. > > I would've thought that if I deleted the sheet by accident, then I > would've lost all the views that I put on the sheet, but they are still > there, floating in space! > > How do I get the sheet back, or do I simply make a new sheet, move all my > views onto that sheet, then delete the sheet that is missing the border? > > HELP!
